Hi Steve, I’ve broken my Double glazed window and need to remove the blind before they can replace the glass. Is it best to put pressure in any particular angle to get the blind off? Scared stiff I’ll break it! can you tell me where the fitting is fitted to ie will it still work with a new window? Thanks.Hi All
I know this an old post but the question still neds answering based on my fruitless searches today. I finally found the answer when I dug out the paperwork that came with the blinds, a comprehensive set of maintenance instructions so check there first. The original post looks like the recessed window blinds that attach to the window beading. These are removed by inserting flat bladed screwdriver, 5-7 mm wide, under the end of the rail and levering off from the hidden clips. You cannot access the clips with the rail in place. To refit engage the rail in the back of the clip nearest the glass and pulling rail towards you roll the rail down onto the near side of the clip. It takes a fair amount of pressure to remove and refit the blind. I'll try to upload instruction sheet but my first attempt failed.
