Hi I have an electric fire and the motor for the flicker flame burnt out
the number on the old is SP-5812 240V V MOTOR CL.B
I have purchased the same motor with all the did gets the same apart from the last didget which is F instead of B
I looked it up and found that the F means it higher heat resistant
I have wired it up but the motor is spinning in the wrong direction
I have swapped the wires but still same direction
Any ideas how i can rotate in opposite direction
