Door Handle Screws
Jez
Any help with this door handle problem would be much appreciated.
I have lost the screw that holds a door handle onto the mechanism of a double glazed door. Is this a grub screw and where can I get one ?
Many thanks.
Welcome to the forum Jez. :)
Unfortunately not enough information but here's a suggestion assuming you have the door handle; have a look on the web for a local nut & bolt/fastener supplier and take along the handle. Locally we have two such suppliers;
https://www.bapp.co.uk/
https://beta.companieshouse.gov.uk/company/01479617
These companies are very helpful in matching threads etc; I know Danlett has a minimum order value but it won't bankrupt you. I have a decent well equipped workshop with thousands of machine screws to hand so all I would need to do was to match the thread or even cut a new thread.
Good luck.
Michigan
Do you still have the 2nd screw/does it have another screw? you could take that to a hardware store and match?
Post a pic if you can to help describe what you're dealing with
