Breather membrane on roofs
Should the breather membrane be visible after the tiles are fitted? How can I rectify the problem?
It should only be visible where it drapes into the gutter to provide a drip edge.
You need to say where you can see it.
If it's the gutter drip edge, leave it alone.
Shaftesbury, Dorset
There is a board referred to as 'multiboard', which is a fibrous sheet maybe 5mm thick that I line exterior porch roofs with if the client requires a clean look of the timber construction. It is commonly used as a cavity closer.You lay it on top of the timbers, under the battens. Then continue the rest of the roof as normal.
