- Joined
- Oct 3, 2015
- Messages
- 112
- Reaction score
- 21
I have now declared a quest. I have an old (ancient perhaps?) Ryobi tiller/cultivator that used to run OK. Last fall when I went to turn over my garden, no go. I figured I'd get to it as a winter project. But here we now are, almost tomato season and I dug out the tiller. No go...... So here's what I did
New spark plug
Fixed crack in fuel tank
new fuel lines ( I am sure I have them connected right)
new primer bulb
new fuel filter
carb rebuild, then a new carb
clean up of coil and flywheel 'contacts' (I think I got clearance right, about 010)
new gas mix
Pull, pull pull......the best I could get was a short run burst on starting fluid. But only one time........with spark, ought to pop with ether.
Checked the spark plug lead , checks OK with a tester, with plug out, got spark across gap and plug grounded
removed lead from shut off to make sure it was not shorted
I am now pulling my hair out
Only thing I can now think of is can the magneto be weak and not fire the plug when it is installed? I will go back and check flywheel, coil gap but I am not sure how much difference that will make just to get engine to pop? I read about the flywheel magnets can get weak? But they seem pretty strong....they grab a screw driver vigorously
Anybody got any other ideas? This is now a quest...
When I put in the new carb I opened the mixture needles about 1 3/4 turns.
New spark plug
new primer bulb
new fuel filter
new gas mix
