Wooden gate frame design
What about a double door idea?
If you install them with a stile, the both doors could be open for larger items (should they ever been needed)?
Either case, ensure you install a vertical member from the lower hinge to the upper end of the door (or both). See below:
Ireland
Nice idea but I only have one gate.
The back of the gate is braced so I think I’m covered there. It’s just the gate post / frame that I’m not sure about, I have around 7” / 175mm is either side so do I just fill the space with 2x4” posts?
Ireland
Ok under pressure so need to install this gate, in this opening? Any advice that doesn’t involve a different gate?
