Wood door glass insert removal
I would try applying Acetone, pouring small amounts of so as "wet" the glue that must be holding the glass in. The Acetone won't stain/damage the glass (provided there is no frosting film on it).
If that doesn't work, try heating up the glue with a heat gun (or a blow dryer), and GENTLY prying up the glass, slip a small piece of paper beneath and keep work at all the way around....heat, pry, paper.......
