18 thou per degree F.50 feet is not long enough to worry about intermediary expansion couplings. The assembly (as a whole 50' run) will expand on it's own as a whole length without buckling somewhere in the center of the run.
Only if it's constructed in a way which accomodates expansion and contraction.Those calculations are likely correct (18 thou per deg F), but on a 50foot run, the expansion can occur at the ends.
