There may be several causes for the improper working of flush. It doesn't mean that you need a new toilet or require the help of a plumber. There are many DIY tips to solve the issue. Following are some of the main reason that causes the problem.
- The water level in the tank is too low.
- The toilet is clogged with toilet papers.
- The flapper is bent or wrapped.
- Lift chain isn't working.
Above 4 reasons we can have solutions,
If your toilet is clogged, use a toilet plunger or toilet auger to push waste. When the water level in the tank is too low, check the water valve and fix it fast. You have to buy another flapper if the old one is bend or wrapped. When the lift chain isn’t working you can solve it by adjusting the length of the chain. As per requirement you can either shorten or elongate it. This allows water to flow when the handle is pulled.
A vast majority of cases can be fixed quickly and easily by yourself. If it is not possible, time to call a plumber.
