- Joined
- Nov 24, 2012
- Messages
- 1
- Reaction score
- 0
I suffer from noisy neighbours. The noise is either m usic, their child crying for hours on end or them having sex :?
I've been researching soundproofing for a while. I was set on using green glue. I was planning on building a 1 inch thick stud timber frame to the existing masonry wall. Then attach 9.5mm plasterboard to the frame using screws. Apply green glue to this first layer of plasterboard and then install a second layer of plasterboard over the first one using screws. Seal all joints with acoustic sealant as I go. Then tape and joint the plasterboard joins.
However, I'm now looking at Mass Loaded Vinyl. I've found a website which sell a product called NSSW2+ which is made of two layers of acoustic plasterboard, sandwiched between 5mm of mass loaded vinyl. They suggest I attach these sheets to the wall using drywall adhesive and use acoustic sealant between the joints. I will then attach a further layer of 9.5mm plasterboard and tape and joint the plasterboard joins.
Both methods will cost roughly the same amount but the MLV option uses less space.
Any ideas on which is better? Thank you.
