Shower Base Replacement
Hi all,
I live on the 26th floor of a condominium apartment building. I need to replace my existing shower base (picture attached - as you can see it is quite a small space and several things need to be removed before the shower base can be removed).
I am in the process of budgeting how much I should be expected to spend on this project. I have a good understanding of labor rates and the cost of the shower base. What I don't know is a reasonable amount of time required to do the work. I have been advised I will need to hire two contractors to work at the same time.
Is a time estimate of a day (say, 8 hours or so) reasonable?
rapid
