I am a homeowner. I have a 2 story detached garage, built about 100 years ago. The second floor is a nice space (20x20); the roof is gambrel, with no walls; it is 2x4 rafter construction, 12" centers. It is not vented--either on the roof ridge, or at gable ends. I want to use the space as a shop area, and I don't intend to heat it. It is fine with me if it is freezing cold in winter (I live in New York city area).
So, I would like to sheetrock the interior, mainly to paint it white, and improve the lighting. I don't want to insulate, to save the money, since I don't want to heat. So, my question is, will putting sheetrock on such a system cause condensation problems? Putting sheet rock on will effectively seal the cavity between the rafters; so that is what I am wondering about--is that a problem?
If so, I was thinking of leaving a 1" gap at the bottom of the sheet rock, where the rafters connect to the wall headers--and leave a 1" cab where the sheetrock meets the curb assembly (I think that is what you call it--it is a double 2x4 girder that forms the joint between the rafter run from the floor to the curb, then a new shorter rafter runs from the cub to the roof ridge) -- So that gap would vent the first, floor-to-curb rafter bay--then do the same on the short rafter run--leaving a gap at both ends to facilitate air movement. I could then install 2 gable vents on each end.
So, would just sheetrocking, with no gaps be ok, or should I leave the gaps and install gable vents?
Thanks for help--it seems impossible to find answer to this question, as all information is about insulating--I don't want to insulate.
