- Joined
- Sep 11, 2019
- Messages
- 1
- Reaction score
- 0
- Country
Hi folks! About 6 inches from the bottom of our garage door is rotten (behind where the metal base cover should have been properly attached to/see close-up photo), and the paint is of course peeling away. Apart from the metal supports, the door is made up of 8mm~ thick plywood panels (the base of some are suffering the rott), that are very large and would be hard to replace. I’m thinking to buy some sort of PVC plastic panel thats big enough to cover all along the rotten section, likely with some sort of glue and then seal the edges, but thats just a guess, and would really appreciate your advice/ideas. If by chance I’m on the right lines, what type of PVC and glue would you recommend? Also thought that once I remove that metal at the bottom, I could use some Minwax Wood Hardener to help ensure the rott doesnt spread (worth doing even though I’m covering it up?). Attached photos should hopefully give you an idea of the issue. Thank you!!
