Taking out the old exterior door leaves a pretty wide rough opening. A special order door is too much and takes too long to get. so the plan is to build up the opening by adding some wood. I don.t have plywood but I do have some OSB. Will it work.?
What is the construction method of the existing wall?Yes
a door will be installed and expected to be there a loong time
