- Joined
- Apr 28, 2012
- Messages
- 2
- Reaction score
- 0
My bathroom has a suspended ceiling which makes the electrics behind it totally inaccessible (without bringing the ceiling down). Currently there are 2 low voltage halogen spotlights. One of them started intermittently dimming and then totally going out.
I switched the bulbs but the problem stayed with the fitting so I switched the fitting and the problem appeared to move with the fitting. However, the position which was originally faulty (which I moved the apparently OK fitting to) has now begun to start getting unreliable.
This points to the transformer, right? As well as the fitting I moved from the original, faulty position. (There is a separate transformer on each light.)
I guess I could just replace the faulty transformer and both fittings for the most economic solution, right? I'd have to cut the 'in' wire to the current transformer and wire in the new one to that wire as I can't get to the source of the current mains-in cable. Is that OK?
However, I'm thinking about replacing everything with LEDs. That would mean cutting the 'in' wires on the existing transformers and connecting the new fittings to these wires. Is that OK?
As you can tell, I am somewhat inexperienced at electrics so I'm just keen to validate that my proposed solution is safe and achievable. I do not want to make a mistake where the only solution is bringing down the ceiling - that would be a divorce issue!
TIA!
Pete
TIA!
Pete
