Replacing Halogen Bulbs on Security Light
I have a Timeguard SLB400G 400W security pir light in the garden. The bulb recently blew and requires replacing.
Is it possible to replace this with a lower watt bulb i.e.120W? 400W gives too much light so was hoping it wouldn't need a direct 400W light replacement.
Surrey
Hi sfrazi
I'm not sure of the bulb type in that fitting, but if 118mm linear, R7 bases, then, yes 120W is easily available. Remember not to touch the bulb when fitting, use a bit of tissue.
rapid
