Hi, I plan to remove a false chimney breast to create space for a media wall. The chimney breast is solid brick but only protrudes 11cm, so I'm hoping it is built 'against' the main wall rather than integrated with it. If so, taking it out shouldn't be too tricky. My question is, what should I do with the wall behind the chimney breast once the bricks have been removed? It will be covered by the stud media wall but should I still finish it with plaster board or something so that it is tidy and insulated? I imagine I'll be left with breeze blocks but not sure.
