- Joined
- Feb 21, 2013
- Messages
- 2
- Reaction score
- 0
I have recently changed our downstairs layout and installed a dedicated dining room, I now need to modify considering wiring and plumbing in the ceiling above this new room, coming in from above is impossible due to bedroom furniture and recently decorated room.
My only option is to remove considerable amounts of this ceiling space, room is 3.2x2.3mtrs btw. Having drilled some tester holes I have noted the ceiling is around 25-30mm thick. I would intend on replacing this ceiling with 12.5mm fireboard, and having it skimmed.
Is there anything else I should be aware of, or should this be fairly straight forward? I will remove in small chunks of say 2x2 ft due to weight!.
