Hi All
I have a Grundfos Mains Booster Pump in the loft - it provides pressure for all the hot water, and most of the cold water flow in the house.
The pump is mounted on a 3-4cm thick piece of sound insulation board, on a piece of wood which is attached to a metal bracket, which is itself then attached to the chimney breast wall in the loft. The pump is in a plywood (I think) box, which is then surrounded by more insulation material, and then by another box.
The pump is on a timer, so that it doesn't run overnight.
The problem is that despite all the insulation, the pump is still very audible throughout the house, particularly in the bedrooms when it comes on first thing in the morning to refill the tank (I presume) of any water that has been used since it was turned off the night before.
I have now asked 3 plumbers for help in reducing the noise - either by adding rubber between the pump/wood and bracket/wall, or by moving the pump to an external wall, and none of them seem to want to touch it!
Can anyone suggest any other ways of reducing the noise - and can anyone explain why this seems to be such a scary job? Is it that hard to disconnect the pump and reconnect it (which would need doing to put rubber in or to move the pump)? All the plumbers have made comments that they worry that when they reconnect the pump things might not work right - am I missing something obvious about how these things work?
The only other option I can think of is to move the timer switch to somewhere out of the loft, set it to not come on so early, then manually turn it on if we need it earlier than it is normally set! It doesn't really solve the problem as much as avoid it...
If anyone can recommend a plumber in the SW London area who would know about these things I would be REALLY grateful!
