I have a hall floor which is a total of 8m2 which needs raising and levelling between 5-40mm in total.
Some area's not much is 40mm and other are from around 5mm and some about 10mm etc..
I wanted the most cost affective method of raising and levelling it.
I have looked at the Wickes levelling compound but this would be expensive to use this for the whole depth and area - about £500
I thought about putting a concrete mix down but not sure if this would crack as the depth wouldn't be much in some area's.
Does anyone have some advice on this please?
Thanks!
Thanks!
