Hi everyone,
I'm repairing a leaking and partially rotten skylight window. I've started using putty but it seems such a different material to what was used originally that I'm wondering whether I should be using something else... Does putty actually harden to something really solid and brittle like the material I'm replacing (see pics) or is this original material something other than putty? If some other material *was* used, would that have been a mistake? Or am *I* making a mistake using putty (it seems an implausibly huge bead of putty is needed to recreate what was done originally). If so, then what *should* I be using...? Hopefully the attached pics should make that clear: 1) the skylight, 2) the original glazing material, 3) my stalled putty repair.
Thanks!
Thanks!
