- Joined
- Feb 26, 2011
- Messages
- 2
- Reaction score
- 0
I'm having a problem with a lightswitch, which is a dimmer. It's also connected to an outlet in the room. The switch has stopped working, and now neither plug in the outlet works either. Previously, one was controlled by the switch, but both were not. Any idea if this could be an easy problem to fix (new light switch? new outlet?) or if this is definitely a job for an electrician?
Slightly more info: I'm told the light flickered a few minutes before it went out. And yes, I have turned breaker on/off. There are also two other light switches in the group, but both of those work, so i'm guessing they're wired independantly...
Thanks for any help/suggestions
Mark in the Dark
Mark in the Dark
