Doing a bit of computer tidying I came across these photos.
i put these in some years ago. They run off mains pressure. They are only suitable for small gardens like ours, if you've reasonable water pressure. I put them in one afternoon. Total cost about fifty quid. Can't say they are used that much, but certainly quite often last summer.
This was the "dry run," Well...Wet run, to make sure they would work. The supply has to be midway between the two heads to balance the pressure.
Just a case of taking out six inch deep wedges to install the speed-fit pipe.
a recycled central heating valve controls the flow. I had bit of spare sand and cement, to remake the path over the supply pipe.
You can adjust the heads to miss out a section. Here, the spray doesn't hit our teahouse.
They've worked perfectly every year, despite not being used for months at a time.
The "how to" is in the write up of the video.
