I've briefly mentioned this previously but I can expand on it a bit more. Many years ago I laid lots of very heavy 3' x 2' x 2" paving flags leaving gaps for pointing and to allow individual flags to be lifted if ever needed; I found it backbreaking slow work so I wanted an easier method; this kept me awake one night in the early hours as I gave the problem some thought.
I had stripped a computer tower saving the sheet steel sides and one of these looked ideal for what I had dreamt up; one edge already had an upright of about 3/4" forming a lip but I then wanted a second shallower lip to slip over the edge of the flag this I did by clamping the sheet between two lengths of heavy angle iron then beating the edge over with an hammer this new lip only needs to very shallow of about 3/16" deep.
What a huge transformation this made not only in speeding up the job but aiding neatness getting the mortar just were needed and not all over the face of the flags; it cost me nothing the hardest part was dreaming up the idea.
The computer side measuring 16" x 14" The upper lip prevents mortar sliding from the tray.
The underside showing the shallow lip.
Some of the patio flags pointed with the aid of the tray.
More pointing showing how neat this method is.
Pointing underway; the tray is slid along and to use it locates to the flag edge allowing mortar to be simply raked into the joint.
Another picture showing the tray in use; once the mortar is in the joint it's a quick job to go over the top to finish it off flush with the flags. I've been using this tray for many years and hope the idea is of use to others; it definitely works.
