- Joined
- Mar 4, 2022
- Messages
- 2
- Reaction score
- 0
- Country
Hi, All.
So I encountered this peculiar problem and I thought I'd seek some wisdom. There's quite a points I'd like to mention so I'll try and condense into a still rather long bullet point list!
Any ideas what this mystery green stuff is and how I could condition/attack it so that emulsions will actually adhere to it?
Thanks.
Matt.
- Started decorating my house for the first time and started on a bedroom.
- All walls were painted with a thick cream paint, looks like someone did it all in a single coat and it looks awful.
- I removed some lining paper that was only on one wall and cleaned the paste off, revealing a semi-gloss-like lime green paint.
- The lining paper was really badly done and I thought at first they didn't use enough paste.
- The other walls just had the cream paint on the green paint (I could see in some patches after sanding back the old paint so that it was flat).
- I thoroughly cleaned the walls & filled in damaged spots.
- Painted the walls with a flat vinyl emulsion.
- Third coat finally covered the green paint, but started bubbling.
- Even the old cream paint started to bubble once fully wetted by the new coat.
- Bubbling only occured directly on the green paint (not the patches I filled).
- I tried sanding the green stuff to remove the shine but it clogs the sanding paper almost instantly and also goes super flaky creating a awful surface for painting.
- I decided to scrape the green paint off over the next week, it was on there like glue (a full weekend and 2 hours in evenings after work).
- The smell that came off the green paint after I removed it (from the revealed plaster) actually gave me a headache at one point. Strong chemical smell.
- The damage was so bad that I ended up using lining paper after using a ton of filler.
- Job is done now and it is a really good result. But it did take me almost 3 times longer to decorate the room than it should have.
- I then discover the entire house has this green paint...
Thanks.
Matt.
