Hi Guys
I have been trying to get a tradesman to fix a window where the putty has come loose on a 1st floor window sill (see attached picutre)
Eventually i gave up and managed to get up there to fix, trimmed and replaced the putty etc no problem.
I noticed there was a gap of about 1 cm on either the side of the sills - it thought it was pointing failure, it seemed big for silicone to bridge so i filled it with expanding foam and sanded it back
I then thought about thermal expansion, there is no longer a gap either side of the window sill.
Is this going to cause me a problem come summer? do i need to get a window guy out to fix my screw up?
One of the gaps i filled is visible on the attached
Thanks.
Thanks.
