Does anyone have experience installing a basement exhaust fan? I did some staining downstairs last weekend and I really stunk up the house with all the fumes.
There are no windows, so boring a hole in the wooden part of the wall will be necessary.
What I'm picturing is one of those fans that fits inside of a section of ducting, that can be tucked up between the floor joists. On the incoming side I plan to have a lenght of flexible ducting that I can position near where I'm working.
1. The fans I looked at don't move much air until you bump up to an 8" diameter fan (500 CFM).
2. Most dryer vent outlets that I've seen only go to 6" and the 6" fan only produces 250 CFM, and I'm not sure that's going to be enough to exhaust paint and stain fumes or sawdust.
The fans I'm looking at are primarily used to help move air in your HVAC system. Is there a different type I should be looking at?
