Old Myson Economist WM 60 /80 BF boiler. When I turn heating OFF either at the programmer or by the room termostat while the boiler flames are ON (boiler thermostat ON) there is banging in the boiler for a while. This does not happen when the heating is switched OFF while the boiler flames are OFF (boiler thermostat OFF). It is an open vent system with two motorised valves (heating and hot water) , Grundfos pump and bypass.
When the programmer timer is ON and the room thermostat is calling for heat ( which right now is most of the time during the daytime) boiler and pump work normally and quietly with just the boiler thermostat swithing ON and OFF .
I suspected that pump overrun was not working correctly but I am not sure now. It turns pump ON after heating was turned OFF but not immediately. Looking at the wiring diagram ( see enclosure) it seems to me it cannot be immediate.
Any suggestions as to what could be the reason for the banging would be appreciated
