Hi there,
We bought a new light fitting and I made the mistake of not taking a proper note of how the old fitting was wired.
There are two twin & earth cables coming through the celiing. I'm assuming from this (maybe wrongly) that this is the last light on the circuit. I've wire this as I think right, the two live (brown) in the center loop terminals, one neutral going to the flex live and one neutral going to the flex neutral, the two earths are connected as this is a double isolated fitting and as such doesn't have an earth. I've tested and this works, well the light goes on and off with the switch as required.
My question to you is, can this work and still be wired wrongly? I was going to switch the live and neutral of the flex over to test but thought better of it. If it is wired wrongly I'm guessing it could be a fire risk etc? Or is this a case that it will only light if wired correctly and it won't work other wise and there is only one way to wire it?
The moral of the story is, take a pic on your phone before charging in, lesson learnt (again!)
Many thanks
Phil
Many thanks
Phil
