- Joined
- Dec 25, 2016
- Messages
- 3
- Reaction score
- 0
I have a Mitsubishi a Mr. Slim Mini Split System. The indoor air handler unit is a ducted SEZ-KD12NA, Serial #99M00519 and the outdoor heat pump is a SUZ-KA12NA, Serial #02P00028. The thermostat is a PAR-21MAA . I can set the thermostat at 63 degrees on "heat mode" and the unit will remain on heat and not shut off, even when a bulb thermometer is showing 80 degrees. The thermostat temperature will show something in the neighborhood of 68 degrees. Anyone have any idea #1 why the thermostat gives a incorrect temp reading and #2 why the thermostat temp exceeds the thermostat set temp without shutting off.
