This is a follow on from;
https://www.diy-forums.com/threads/brazing-tc-tips.290598/
I'm adding this for interest only and not to encourage anyone to play around with mains electricty which can and will kill given the slightest chance so if you copy this you do so entirely at your own risk of serious injury or death.
I've watched many YouTube videos showing how to convert an old micro wave oven transformer so here's my version which seems to have taken forever due to no end of problems and Covid messing everyone's life up. It's a brazing machine where the transformer secondary winding is two turns of 500A welding cable but I'm aware this drops amps to 975A hence the need to control the beast otherwise the cable will quickly overload and burn out.
My micro wave transformer is a commercial high power 1950W bought through eBay. Many of the videos are simply crude just applying full mains power but I wanted to experimant and try to control output amps; controlling amps is difficult but controlling volts is much easier at least it is for me. Years ago a friend told me about a very cheap Chinese motor speed controller he had bought so could I incorporate one of these working on the principle amps x volts = watts; if I drop the volts will it control the amps?
Motor speed control circuit board; connections are very easy indeed but what isn't stated is that these only work with a brush type motor which I found out the hard way but to cut a long story short this speed controller actually works with my transformer; I do lots of experimenting enjoying these projects. "Fan" connects to the motor live.
Here's another refinement it being a timer with timing right up to 30 minutes depending where the jumpers are positioned. I removed the potentiometer and discarded it instaling a new much heavier duty potentiometer of correct 500K ohms allowing remote control. I've since bought two more of these circuit boards but they look to have remote potentiometer supplied which is much better.
Here's a 3/4hp motor being used to test circuits rather than connect the transformer and where I found out the motor speed controller circuit board doesn't work because it's not a brush type motor?
The motor speed controler mounted on a backing plate using "stand offs" making it easier to securely mount safely.
Please don't do this unless you've a lot of experience; I worked restoring vintage valve radios as an hobby for ten years and these vintage radios are truly lethal with live chassis so I'm at home with this knowing the risks involved.
In order to run the controls from a safe 12VDC I added relays; these having the 12VDC coil but capable of switching up to 15A 240VAC; a great deal of extra work and planning but I was experimenting; I used a 1A 240VAC to 12VDC printer power supply. I don't throw old switches or power supplies away they are handy to play with.
I'm not electrically trained so please don't throw stones at me after all I'm only sharing what I like playing with. It took four redesigns before finally getting the relays in their correct places; I used "Emachineshop" totally free CAD which I've used for years to draw the circuit; this CAD is the only one of many I tried and can actually use; the others both free and bought I struggled just to draw a straight line. I first came across this CAD whilst wanting to make 45 cast iron gears and was delighted to find it contains a "Spur gear wizard".
The front of the machine showing the electrodes; it's virtually a spot welder by design.
The toggle switch is the manual control at the top; the momentary push button at the bottom is pressed once to engage the timer; the large rocker switch is mains power the smaller rocker switch supplies either the motor speed controller or timer each isolated from each other; LED's are included these on 12VDC. The top control knob regulates the motor speed controller the bottom knob regulates the timing period; it's fully working and I've heated the end of 10mm square BMS bar stock to cherry red; I need to experiment more with the electrodes the 6mm dia solid brass are prone to over heating but at the moment I'm busy elsewhere so can't play further with this project.
I've been on the go since getting up at 6 o'clock this morning and am tired out so time to call it a day; I hope this story makes sense but I'm short of time to expand further; it's the downside of retirement; not enough hours in a day and now at 73 less energy than I used to have; I think I'm slowing down.
