Maytag centenial dryer
Just stopped heating today any suggestions CLOGGED VENT CAUSE THIS no heat at all
THANK YOU
Ayrshire
Suggest you try the following? may assist.
If the dryer needs to be reset simply because the cycle needs to be changed, stopped or altered, press "Power/Cancel" once to cancel the current cycle. Select the new desired cycle, followed by any modifiers and cycle options. Then press "Start/Pause" to begin the new cycle.
And / or?
If your Maytag dryer is not heating, it is possible that it is not being supplied with the proper voltage. Most electric dryers require two legs of 120 volts AC that is equal 240 volts. If one leg of voltage is shut off by a tripped breaker or blown fuse, the dryer may be able to run but it will not heat
Also
If your dryer won't start when you push the start button, the most likely causes are a lack of power, a defective door switch, a blown thermal fuse or a bad start switch. ... Open the dryer door and check if the light inside the dryer turns on. If it doesn't turn on, it's likely that the dryer has no power.
Ken
I realize your dryer isn't a sears but gas dryers are so similar in parts and operation, especially safety features, that I thought the link may be useful.
rapid
