Was getting no heat during run-time, so disassembled dryer to perform ohms tests with one wire unhooked. Results:
Heating element: thermostat-->passed
Heating element: fuse-->passed
Heating element: ground check-->passed
Blower housing: fuse-->passed
Door frame: Moisture Sensor Bar-->Failed
With the dryer disassembled, and electrical power and gas turned on and when depressing the open-door limit switch, pulling out the start button (intellisense, and timed heat as well as gentle, normal temp), there is no flame.
Question is: would a failed moisture sensor bar prevent needed feedback to the system that's required to ignite a flame?
