I am going to enclose a corner inside my garage as a room , I plan on using 2 existing walls, and building
one solid wall (2x4 framed with sheetrock) , then the forth wall(2x4 with sheetrock) with a door.
I plan on anchoring the new walls to the concrete garage slab, however if I wash out the
garage on occasion this will get on the sheet rock at the floor level and eventually deteriorate .
What should I do at the bottom, should I build it up a few inches with maybe a cast lentil, or
what would be a good recommendation ?
