Loft leak help
Hi all
First time poster requiring help
Got a small leak in loft only really appeared after we stripped the wallpaper of with a steamer
There’s no obvious sources of water in loft no sign of tile damage on roof albeit looking from a distance not up close
We have had condesation issues in loft in the past but a couple of aero 360 normally clears the problem
My question is could the steam from the steamer make the condensation worse in the plaster on the downwards facing ceiling as there appears to be only A little water on insulation fluff inside the loft
Also I have moved the fluff away in the offending corner to inspect the back of the plaster could doing this be making things worse
Ocin400
