I did some remodeling and had to rearrange some electrical wiring and unfortunately I messed up the original setup of the electrical wiring to the light switches. Here's the run down... I have four light switches, two of the four light switches control one light and the other two light switches individually control their own light. The two light switches that control the one light is were I have the problem. I can only use one light switch to control the power to the light. For example, if I use light switch #1 to turn on the light, switch #2 does not allow me to turn off the light. Vise-versa. I hope that makes sense. Here's an illustration. I just need help to rewire all 4 switches correctly. If someone has a diagram or can illustrate the wiring I'd appreciate it. Thank you.
