HI All!
I want a bit of reassurance on some wiring I’ve recently done.
I installed 3 0.9w candle downlights in my bathroom, they’re on a dimmer which flickered when originally installed, I installed the adapter that come with the switch but the adapter does get quite hot.
It’s not untouchable, but if you hold it for more then 5-10 seconds you have to let go.
I installed the adapter before the transformer in the twin & earth leading to the lights – is that right? Or should it be installed after the transformer?
Hopefully someone can help.
Thanks in advance
Thanks in advance
