The cold water tank in my loft developed a slow leak, which only became apparent a few days ago when drips came through the bedroom ceiling. The leak has been repaired, but it is clear that there has been a slow leak there for some time, which soaked though the insulation and into the plasterboard ceiling, which has sagged away from the joists. Mostly repairable - remove the damaged ceiling, dry out the area and replace - just awkward to work under the tank.
BUT.....there is this white strand-like growth started on one of the joists (see picture attached). What is it please? Clearly it needs to be cleaned off, but might it be a symptom of a more serious problem eg dry rot (I hope not!).
