- Joined
- Jan 28, 2017
- Messages
- 1
- Reaction score
- 0
I'm installing an alarm system and want to convert a light switch to a power outlet so I can have an easy spot to plug in the panel. The perfect spot in the house also happens to be by a light switch that seems to have been altered to provide constant power to some nearby (previously switched) outlets. There's only two outlets that I can find that seem to be connected to this circuit. When I cut the breaker to the light switch, the two outlets also turn off. It seems kind of an odd wiring, but I admit I'm new to this.
In the attached picture I've numbered each wire involved.
What sort of setup is this? Or is it just a rigged setup to allow the 2 outlets to always stay on?
Here's what I think I should do if I want to put in a outlet:
Any issues with doing this?
- 2 & 3 feed into a wire nut, that then feeds into another wire (#6) that was connected to a light switch. These wires are all hot.
- 1 (red) is also hot. It was connected to the other terminal of the light switch.
- Both the on and off positions of the switch did not affect any nearby outlets, and with my multimeter I found a current was still traveling to both terminal of the switch. This tells me that two hot wires were being fed into the switch.
- Put a wire nut on #1 and stuff it back in the box.
- Cut off #6 and it's wire nut
- Connect #2 to the top hot wire terminal of the new outlet and #4 to the top travler/white terminal of the new outlet
- Connect #3 to the bottom hot wire terminal of the new outlet and #5 to the bottom travler/white terminal of the new outlet
- Connect ground one of the two ground wires to the outlet.
