- Joined
- Mar 30, 2012
- Messages
- 1
- Reaction score
- 0
Something weird is happening. I place my pressure instrument on the Schrader valve of the expansion vessel to measure the pressure inside the vessel. Reading: Nil. I repeat the exercise with another pressure instrument. Reading: Again Nil.
How can this be? because I am certain that there is at least 4 bar in the vessel.
Are my pressure instruments defective? Certainly not, both instruments show the exact pressure in the tires of my car.
I have a small black and decker air compressor. You type in the desired pressure you want to inflate to and then hit start. The air compressor starts up and when it reaches the desired pressure it automatically shuts off.
I set the air compressor to 3 bar, attach it to Schrader valve of the expansion vessel and then press the start button on the compressor. The compressor temporarily starts up and then immediately shuts off displaying that the pressure in the vessel is already at 4 bar.
So there is 4 bar pressure in the vessel. Why do my pressure instruments read Nil?
By the way, when I depress the needle in the middle of valve, it goes in just fine but no air comes out. Consequently I cannot reduce the pressure in the expansion vessel even if I wanted to.
Has anyone encountered this type of problem? Is this typical behaviour of a valve?
