- Joined
- Sep 24, 2019
- Messages
- 8
- Reaction score
- 1
- Country
My 60 year old furnace has been faithfully working perfectly....until recently
I replaced the fan last year.
The fan control switch went out.
After kinda familiarizing myself with it, I'm worried about the gas solenoid valve.
From just looking over the system and schematics, it seems possible that the gas valve could fail, in the open position, and there would be no other safety system to cut the gas off. If it was running (which i guess is the only way it could jam open) It would over heat, and not even the limit switch would be able to stop it. It cuts power to everything, but the pilot is just a pilot. It burns 24 / 7.
If for some reason the pilot went out.......It would be an open path from the supply through the gas chain, and into the house. That scares me.
I cant afford to replace the system at the moment.
Should I preemptively replace the solenoid. Are proper replacements available for old furnaces?
