HI.
We need to remove an electrical ceiling rose from the living room as we have bought a new light that doesn't need it.
How can we do this easily?
The picture of the rose set up is included
If you aren't confident about doing this then you should get in an electrician. I'm not even sure if you're legally allowed to tackle this yourself as the law changed in 2001.
The simplest solution if I were to tackle this is, to disconnect the wires hanging down which I assume were for the light fitting.
But I would first need to turn off the power for that floor's lighting circuit from the consumer unit
Turning it off from the wall won't isolate the power.
The other wires you can see are part of the lighting circuit for the rest of the rooms on that floor and to the wall switch.
I could buy a blanking cover to screw back over the rose, rather than remove the fitting and reconnecting the necessary wires for the rest of the rooms. After a week no one would notice the little round cover in the middle of the ceiling. Then if in the future a centre light was required it would be easy enough to reconnect it.
Completely removing the rose would leave a hole in the ceiling, which would be difficult to patch.
