Hi folks!
I bought these 3 things:
• Leviton 8806 Bayonet Base, keyless, HID, Glazed Porcelain Lampholder
• Fulham WH2-120-C Workhorse Adaptable Ballast
• Philips 327817 35-watt T15 SOX35 Low Pressure Sodium HID Light Bulb
But I don’t know a ton about electricity or LPS bulbs and I need to safely plug this in to a regular 110 wall outlet. I’m not sure what the purpose of the Ballast is, but I’m guessing I have to wire it into a power cable that will then plug into the wall. Am I right?
And do the 2 white cables from the Lampholder connect to the Black & White cable on the Ballast?
Any help would be appreciated! Thank you!
