- Joined
- Nov 29, 2020
- Messages
- 11
- Reaction score
- 0
- Country
hi me again, another problem i have is, the kitchen has several different types of under cupboard lights, in one corner which just has a floor double cupboard and a wall mounted double cupboard. there are 2 tube lights under the wall cupboards and these lights didn't work so i replaced the bulbs but still didn't work i managed to follow the wire and it comes out under the floor cupboard but you wont believe this the end of the cable isn't connected to any think so obviously there is no power here are a few ideas i had but might sound stupid to an electrician when you stop laughing please reply.
1) is there a battery type transformer i could connect the cable to under the floor cupboard?
2) could i pull the cable back up and put a plug on it as there is a double socket on the back wall between the floor cupboard and the wall cupboard?
3) is there a way to splice the power cable and add a spur of the cable to put a singe socket on?
many thanks for any advice or suggestions you have ? bob.
