Hi All,
Am planning to move our hot water cylinder from the bathroom to overstairs cupboard soon - a horizontal move of just over 3 metres - and have a couple of simple (hope ) questions for you all...
1) If I remove the existing Myson Aerjec 22 'deaerator' from the pipework - as has been advised by one plumber who has surveyed the work - do I need to put anything in its place? Or is it just a case of venting elsewhere using vertical pipework?
2) Should I look to move the vent/feed tank in the loft so that it sits directly over the hot water cylinder in its new position? Leaving it where it is would mean a horizontal pipe run of about 3.5 metres in the loft and not sure if this would cause any issues.
Any help or advice appreciated.
Thanks!
Thanks!
