I have a Honeywell ST7100 on my CH system. Knowing that the back-up batteries had been in there for some years, I decided to check on them today - bad move :-(
I turned off the 230V supply, removed the ST7100 from its backplate, and tested the batteries - they seemed still good. Replaced the batteries, replaced the controller, turned on the power - various 'clicks', but no display :-(
Turned off the power again, removed the controller, fitted brand new batteries, and replaced controller. Display came back and most of the programming intact, just needed to set date and time. The indicator lights go on/off as expected if you press the relevant buttons to advance the programmes (accompanied by various 'clicks' which I assume are the relays working), BUT......the boiler keeps firing intermittently even when the programmes read 'OFF'. (I have had to turn the boiler thermostat to 0 to stop it!)
In short - is the programmer broken????? Do I have to replace it, and if so is there an equivalent that will fit the same backplate?
