- Joined
- Oct 25, 2022
- Messages
- 1
- Reaction score
- 0
- Country
Hi all.
I’ve moved into a house which has under cabinet lighting which is controlled via a fused switch and looking at the cable going into it, it looks to be connected to the ring main rather than the light circuit.
My question is this - what can I do to make the current setup ‘smart’. Coming out of the switch is a cable which goes to the first light. Picture attached of the connector on the end of it.
I’ve also attached a picture of the current switch and the wiring.
is it possible to put something between the switch and the first light which will make this setup Alexa controlled? Can I maybe wire in a smart single light switch?
