Is it best to use 2 or 3 hinges to hang my door. It's about 23kg and glazed... The previous door was paneled only and about 13kgs. I just don't want to chisel and damage the door and frame more than I have too.
Also the height is quite reduced meaning I might have to take off more than the recommended amount... This is because they have built up the tiles in the kitchen which lead to the door arcitrave, which gives me a step down to the living room...can you advise on this? You. Might be able to see the lip in the bottom left corner.... This is the old door in the photo
