Hi. I have recently purchased a Titan TTB653SDS+ drill. What is the best grease for the gearbox and how often should it be filled up? Also, what grease for the bits. Thank-you
Unless this is an unusually cheap hammer drill, you'll likely never need to add oil to it. Gearboxes on hammer drills are sealed. However, gearbox oil is usually a 75W90. Do not just randomly use any oil though....there are detergents in some oils.
Some standard wheel bearing grease....needn't be high temp.
