- Joined
- Sep 7, 2019
- Messages
- 2
- Reaction score
- 1
- Country
Hi everyone,
I have a Geberit cistern concealed in a wall, for a while now we've had a slight trickle into the basin. It seems to get worse then calm down randomly.
After thorough research I followed instructions yesterday and removed the flush valve and fill valve and checked for the following problems:
- limescale build up: wasn't that bad, cleaned off what was on both parts anyway as per instructions in YouTube videos before re-assembling.
- silicone seal faulty at the base of the flush valve: Cleaned this, there were no water blisters in ours and it looks good as new. This sounds like the most common cause of our problem however ours seems to be working fine? Could it still be faulty?
- adjusted the fill valve so water fills up to 6L. Goes over slightly the first time I refill after turning the water back on, however after that it fills to the normal level .
When we flush the toilet and the tank refills, it seems to be fine for about a minute - no tricking. Then the water starts trickling into the basin. Looking, it looks like water is continually leaking out of the tube at the bottom of the fill valve (the tube which has Geberit written down the middle).
Does anyone know how I could fix this?
I hoping I'm describing it okay, I'd be happy to take pictures or film a little video demonstrating the problem.
I spent 7 hours fiddling with the problem yesterday, trying all the instructions online and troubleshooting based on common problems described in this forum - no luck! I'm really hoping someone might be able to help.
Thanks in advance!
Thanks in advance!
